Hi guys,
Basically, the previous owner of my car decided it would look good to put on some Ripspeed footpedals. They've always been something I've been meaning to change, but have never got round to. I always thought it would be a relatively simple swap, but now I have a problem. Heres a pic
http://img6.imageshack.us/my.php?image=sth70920.jpg
I took off the clutch and brake, and found a metal bit which had been drilled through to fix the pedals on. The original rubber ones just slip over these so it would be easy. But the accelerator is different, the ripspeed pedal has been drilled AND glued, I'm assuming with araldite. Does anyone know what you do to get this off?
My problem is this: If I can get the araldite off, I'm left with a holey accelerator, so will therefore have to find an alternative, such as the tt pedals. If I can't, does anyone have any suggestions as to what to do?
