wozzahotspurs
I am sure somebody can point me in the right direction as i hear that the electric windows is a common fault with seat cars,
Basically both my windows are not working,
Passenger side, has a intamittant problem, it mostly doesnt work using the switch on either side of the car but on the odd occassion i accedently push the wrong switch the window will come down but then wont go back up. (No noise is made from the window unless it decides it wants to work)
Driver side, when pushing the switch i can hear the noise as if the window should be moving but it doesnt, when this malfunctioned it left me with a small gap at the top of the window which is gradually getting bigger i have to manually push up the window at the moment for it only to slowly drop back down.
Please if anyone can advise a way to fix this or a new part i need i would be grateful.
