The strut brace doesn't make much difference. It won't reduce understeer like some ppl say...it will usually increase it on a front wheel drive car as you are stiffening up the front! What it does is make turning into corners sharper and better grip on smooth surfaces. Fitting a rear ARB will
help much more as the strut brace increases body roll (it reduces flex in the chassis)...the rear ARB will counteract this
