Tyre Pressures
pedro-tdi
Hi any one know the tyre pressures for a 130 TDI wiv 205/45/16 tyres, carnt seem to find them in the owners manual.Any help would be appreciated. Thanks Pedro.
robepton
Practical performance!!!!
Dec 27, 2008
110
peterborough
I put 32 in all round. However i think some people put less in at the back because you've got a lot less weight over the axle.
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
i never thought about having different pressures at the front and back, sounds like a great idea for weight distribution :) i usually run mine at 30 each. i wonder if use whats recoommended i'll get a few more miles out of the tank. sounds like its worth a try
________
Amateur Nude
2,141
Mid Wales
You need to check what's listed on the filler cap.
SEAT have worked out the pressures for each car based on their axle weights and tyre sizes. The 33/30 combo listed above is ideal for cars with 205/45/16 tyres, this doesn't mean it will be any good on other models with different sized tyres
george130
157
Norfolk
Actually, i got the impression that tyre pressure is the same regardless of tyre size/profile/width etc... as pressure isnt the same as 'amount of air'. But I agree that it differs between axle weights :) The 33/30 combo is good for TDi 130's, that i know!
Then again im always willing to be proven wrong! :p
Neo
Fool member
Mar 24, 2009
881
I never noticed there is an information plate on the fuel flap! So 32/30 is not a bad guess! :shrug:
I`ve always gone off what looks and feels right for the profile of the tyre, making sure I have good contact and handling without too much bulge. Well there you go!
But by following the manufacturer`s guidelines you can`t go wrong.
Neo
Fool member
Mar 24, 2009
881
just got to hope the tyre guage is calibrated corectly.
True, I do mine in work where the gauges are sent for calibration reguarly, and I use nitrogen which is more stable.
I never trusted the gauges at petrol stations because they get slammed about, but I see them more commonly on the control panel itself now so its probably not as bad.
