R32/TT Linkage
2footpegs
117
hi iv heard that putting a r32 or TT gear linkage will make the gear shifts shorter, i just wanted to know which one out the two is better, will they fit an LCR, is it just a straight fit or do i need anything else and where can i get them from because i cant seem to find them on VW Speed or do i have to go to a dealer and if so what are the part numbers. thanks
2footpegs
117
im not to keen on DIY stuff n jus prefer to buy n fit the part, thanks tho anyway
Nautilus
547
Bucharest, Romania
R32 / TT linkage will do nothing since it's identical :)
Use the Forge Short Shifter set at the maximum inside position. Mine, set in the middle, reduced the throw from ~15cm to ~10cm
~Nautilus
