Hi,
Just had the car back from the garage and as the title suggests I have 11 fault codes that wont clear. The car is running ok but the TCS and diagnostic light came on so thought i'd get it checked. The mechanic listed the codes for me. The codes that have came up are:-
ABS - 0522 - Engine cont with unit
1425 - Tank vent short - ve
1435 - Secont Air relay short - ve
1289 - Exhaust superchrger short - ve
0102 - Air mass signal low
1117 - O2 bank 1 sensor 2 short - ve
1114 - O2 bank 1 sensor 2 resistance too high
1115 - O2 bank sensor 1 bank 1 short - ve
0134 - oxygen sensor - no signal
0140 - O2 sensor bank 1 no signal
1547 - Boost valve short to ve
The mehcanic has advised it may be a bad earth and if they were to have a look at it, it could cost a fortune for labour (£40 a hour) to find the bad earth.
Has anyone had anything like this before and if so what did you do?
Any familar bad earth points etc i could check myself?
The car is standard apart from induction kit and cat back exhaust.
Any help would be appreciated.
