get gear but no drive ?
lil3520
IBIZA 1.9 TDI SPORT 08
Nov 26, 2006
3,000
20
ALCESTER, WARWICKSHIRE
wifes 54 reg 1.2 has just broken down.
loud bang then can get a gear but no driving forward.
had a new clutch 18 months ago.
what would be the loud bang ?
engine still runs.
Dec 3, 2007
2,475
cardiff
hope its not that bad dude. there are a few things it could be be being able to get into gear but not drive is weird. unless its clutch related
lil3520
Nov 26, 2006
3,000
20
wife has just phoned me, garage think its the driveshaft. will get it confirmed whe garage ring her up in the morning.
my mate knows the garage owner, may get it done cheaper.
Torquemonster
301
:( If it's anything like my old Cavalier. 1of the driveshafts hadn't been hammered back in enough after one of the cv gaiters had been replaced.It eventully popped out one day when i was doing a Starsky and Hutch style getaway.It wouldn't move at all, even though it was just the one.Exact same symptoms,no drive but everything else working fine.
Got it done by someone who knew what they were doing after that.:censored:
Disco_Biscuit
Ibiza Cupra Tdi PD200
Jul 8, 2007
175
If the speedo still goes up when in gear probably a drive shaft, if it doesn't and it went bang then most likely the diff has gone. We do loads of them :blink:
Oct 17, 2006
2,141
Mid Wales
Then wouldn't you drive round in circles?
No.
The diff will send power to whichever shaft is easier to drive - this is why your car can get stuck in mud easily - the spinning wheel uses all the power and none gets to the other wheel that has traction. (This is a simplification - but close enough)
If one drive shaft is broken then all the power will end up being sent to the broken end of the shaft (that should be connected to the wheel). No power will get to the other shaft.
:) Some light reading for you -
http://en.wikipedia.org/wiki/Differential_(mechanical_device)
(In particular the bit about loss of traction)
