genuine 400lbs/ft on stock injectors ??
No chance
Your call Will. Im just "quoting" what i have been told. To quote it correctly "near on 400ft/lbs", which i would guess is the high side of 395.
No chance
Well to be quite honest I been having such varied results on the RR with the pipes as they are it ranges from 350-380 depending on the pollen count in the air lol!and the 130 has smaller injectors than jonjay
Turbo dynamics have been in touch with me.
They're replied with:
"Hi Ashley,
We would like to start with the most important issue, the turbocharger is not designed to run 30 psi let alone 35 psi, the turbocharger will fail at these levels, the mapper should be addressing this as soon as possible. We would expect that the torque and horsepower would actually go up with less boost, in our experience as boost levels above 1.8 - 1.9 bar actually achieve the best figures. Anything above this creates far to much heat particularly with the standard intercooler, hence the performance drops."
As you can see, if my boost gauge is accurate - I'm getting 30psi and over of boost. So either my boost gauge is wrong, or I'm packing too much punch which may actually be a power loss rather than a gain and explain why it's gone into limp mode a few times....
i would say run vag com on it to get true boost readings?? then get back to will if they say the same as the guage
Hi Guys
To clarify, the injectors both flow the same... 75mg injection quantity max
