Hey folks!
Done a search, majority of clutch pedal related posts are due to the pedal snapping from the weld etc but couldn't find many about the croaky sound of the pedal!
Basically - even the slightest touch on the pedal causes a croaky, creaky - almost haunted house door opening type noise!
It's even worse if you put the pedal halfway down and release it really slowly.
I've had the clutch replaced so it's not that.
Today I armed myself with a can of WD40 and went upside down underneath the steering / fusebox area, took both bits of plastic off and sprayed like a crazy man - most of it going back over me!
Anyway, still no joy, so it can't be coming from that area, unless i've missed somewhere, it's definately got to be the pedal joint at some point.
I couldn't even see where the pedal welds would be... Is that behind another bit of plastic? ( I noticed a plastic panel held in by 2 clips)
Anyway, any of you folks managed to stop the noise??
