Suspension knock after fitting coilovers
yellowbeezer06
2nd place is first loser
Aug 8, 2006
149
kent
www.kentunicarz.co.uk
Right.....since fitting coil overs the car is knocking its nuts off at the front end, its approx 60mm lower at the fron now i havnt changed arb yet but my lower arm bushes are absolutley being eaten alive. Can i get different lower arms that will stand up to being up faced up further than they are ment to?
Pabs
5,936
Basingstoke
60mm! wow - brave man... I went 35/40mm lower and had no end of arb knocking until I got the H&R arbs fitted. :) Hope you don't use multi-stories too much! hehe
Why not put in some of the poly bushes? supposed to be much harder wearing - plus get your geo. set up properly to help set it up. 60mm is a big drop without adjustments!
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Feckin ell PABS.... blast from the past or what
yellowbeezer06
Aug 8, 2006
149
kent
no havnt changed the drop links yet, i take it you can get shorter ones then, its the lower arms im concerned about as they are being eaten alive with every bump and where i live the roads are dire!
yellowbeezer06
Aug 8, 2006
149
kent
i did allignment at work the other day and it was out slightly, bloody cars
and somebody hit it yesterday ont he road,
scratched near side wing and dented it, scratched my fresh painted mirror and scratched all down the door!:censored:
