LCR Cam Belt
Cupra Ross
Breaks things............
May 15, 2005
1,379
Edinburgh, Scotland
Yes, thats the one you want but you should change the waterpump for a metal impellered one at the same time. Its cheaper from VW spares as postage is free: http://www.vwspares.co.uk/product_info.php?products_id=212
You will also need a hydraulic tensioner damper just in case the one fitted is leaking hydraulic fluid from the piston seal, 9 times out of 10 this is the case.
Water pump: http://www.water-pumps.org/
Tensioner damper: http://www.vwspares.co.uk/product_info.php?products_id=215
Edit,
You'll also need some coolant for when you change the water pump. All of your coolant is lost when you replace this item.
Here you go: http://www.vwspares.co.uk/product_info.php?products_id=1269
You can get away with just buying the basic kit you mentioned but you're inviting trouble further down the line by trying to do it on the cheap.
DanAPR225
79
Cumbria
Thanks mate. I have been looking for this water pump, but cant seem to get hold of it on the net, any ideas of the best place? Same with the damper mate if poss:)
DanAPR225
79
Cumbria
Thanks a lot for that mate, much appreciated. I have the coolant already yeah, but cheers for the thought.
Thats where i looked for the water pump previously, although when you go to the go to shop part, it says that the part was not found...ive tried emailing them, will see if get a response tomorrow!:)
Cupra Ross
May 15, 2005
1,379
Edinburgh, Scotland
any other ideas on where supply metal impellors and which exact one is required?
JBS Auto Designs
Jabba Sport
Awesome GTi
JKM Performance
All of the above should be able to sell you a waterpump with a brass impeller.
All VAG 1.8T waterpumps are the same from 150bhp AEB engine up to 225bhp BAM engine.
Faisal
UK's 1st Liquid Yello LCR
May 27, 2008
1,445
Most likely at work
aparently my cambelt was changed at 60k miles. i was wrong.getting a service today to find that my cambelt was fringed and worn. it was days - literally DAYS away from snapping....how lucky of me....
Lee M
Hi Mate,
I recently brough this: http://www.awesome-gti.co.uk/product.php?xProd=11031&xSec=357
it is a good quality kit that contains everything you need. My local garage were very impressed with the quality of the gear, they said it was good as if not better than the OE stuff they took off!
I think it even contains the new tensioner that Cupra Ross mentions.
Lee
Yes all 1.8t engines are the same.
I you want a pump picking up tim give us a txtd i can bring you 1 home
Hi Mate,
Lee
ayup John
thank for the offer, looking at the kit in the link shown I may have one of these from you next month, im spent up now or should i say money is tied but i'll get in touch with you about that kit, lucks the nuts. ;)
Lee M
ayup John
Yeah good bit of kit mate, worth the investment :)
