I had my TDI Sport 130PD in at Kwik Fit today to get a wheel balanced and while it was on the ramps they did a free inspection. I have a set of Kumho KU31's that are about 10k miles old and the fronts are showing an even 4mm tread across them. The rears are wierd though - as you view the car from behind and left to right the tread on the left tyre is 3, 4, 5mm and then the right tyre is 3, 4, 5mm too with the 3mm now on the inside. It seems wierd to me that the wear is uneven across the car left to right. The fitter described it as steps in the wear like a 50p piece.
I know that this model can have some uneven tyre wear but has anyone seen anything like this on their car? Any explanations cos I'm intigued?
Cheers!
Cheers!
