any one got pics fitting front and back discs and pads
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
This will be an easy job as long as you have axle stands, trolley jack, socket set, pin punches and hammer, copper slip, WD40, a torque wrench and a bit of mechanical know how.
Also SCN guides will help alot.
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
Have a search for Muddy Boots. He seems to be top "handy man" on here when it comes to things like this. Got any pics of the brakes? :)
steve p
peggy
Feb 4, 2009
62
staffordshire
sizes for cupra discs
does any one know the size for front and back discs ive just got some new ones today the front is 312mm and the back are 232mm will they be ok because i think the back ones are 236mm normally cheers
Cupra_Jay
Orange Wheels FTW!!
Oct 25, 2006
927
Pub!!
It is pretty easy to change the fronts...the calipers are pretty easy to get off and the discs are only a few bolts if that!!
the rear calipers are 2 part calipers and you will need a CALIPER REWIND TOOL to compress the rear piston so you can fit the new pads. had to buy one from halfords...was just over £20. the rear bolts require allen keys and (for some reason) mthe rear bolts where Loctite'd in and where a pain in the ar*e to remove!! took a big hammer and some strength to remove.
All in all i reckon to change the 4 discs and pads your talking atleast 2 hours but it depends how good you are with stuff like this
Dont forget to remove the cap for your brake fluid otherwise you wont be able to compress the pistons!!
If you have any problems mate, drop us a PM and i will see if i can help!
TheCraig
Scaramanger!
Mar 13, 2007
80
Tyne and Wear
Am i safe toi drive it?
Guys, Ive just done one rear pad but have knackered my ratchet trying to do the other side:lol::censored::whistle: (the bolt disnt turn at all!)
Am i safe to drive with a full pad on one side and next to nowt on the other? (only to work, halfords and home tomorrow)
Btw, i bought the piston rewinder and it makes it well easy to do
Cupra_Jay
Orange Wheels FTW!!
Oct 25, 2006
927
Pub!!
The fronts can be *******s to do. Some of us have had to cut the pad retaining pins out. There's some info on the AP calipers here:
http://www.seatcupra.net/forums/showthread.php?p=2309514
i didnt have a single problem with the retaining bolts and springs when changing my pads over, all came out with a single problem...had them off 3 times in the space of approx a month!! lol
good info though about the calipers!! didnt know they use the same pads as the clio v6!! would of made my life a lot easier as i ended up buying THREE sets of pads before i found the right ones!! :censored: [:@]
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
Strange it happens to some people and not others It must be something to do with age or the way the cars are driven (by previous owners :rolleyes:).
Mine was over 3 years old but on about 20k miles when I changed them, so they wouldn't have been removed before. 3+ years of dust, corrosion and temperature changes must have made them so hard to dismantle!
