No, isn't that the minimum they should be down to before they need to be replaced?
Prices?
Are all the ATE range 2 piece? i was looking at them last year, and they were one piece then. Look much better in two piece. Deffo getting a set of these when its time.
Ill place bets that the only reason he got them uber cheap is that a customer didnt want them or wrong ones and he got them with massive staff discount. :confused:. Saying that i like.
They are going to be too think and I can't think of a way of getting them to fit properly without the brakes staying on.
Standard discs 28mm. Yours 30mm. You could make them work if you wanted to skim your pads down, but you would have to do that with every set of pads you put in until the disc had worn. Also if the std disc is 323mm and you stick a 326mm disc in there, you could end up with a thin band that is not swept by the pad, which in time would cause problems. Would all depend on how much overhang there was with the original fitment.
This could be worth doing if you are prepared to skim your pads!
