Water level
andycupra
status subject to change
did you check the reading when cold or hot!?
the levels when cold will be lower. So that for most leons when the coolant is cold and in the middle of spec it will be above the top line when fully warmed up.
If reading was checked when hot, its fine.
If it was this level when cold, its probably ok, however it may be an idea to drop it a bit.
