Boot lock problem / Lag problem?
Robb1990
299
You gettin indicator light flash on locking? Just when ive popped the CM fuse when working on my windows, i wouldnt get indicator flash/boot lock. Worth a look in fuse box maybe? its a mini blade fuse 10A
seat_tux
Hmm...sometimes the indicators don't flash on locking, but generally they flash once on locking and twice on unlocking and the boot lock still remains locked.
I've tried turning the lock to the right with the key but it seems jammed in the open position and will only rotate 45degrees to the left.
kineticz
Forever moddin'
Jul 23, 2008
1,958
Shropshire
www.wepaintanypart.co.uk
Well I'm having a problem with my boot again, I locked it a couple weeks back and when I try to unlock it now by turning the key in the verticle position, it doesn't unlock :( Or am I doing it wrong?
Any help appreciated
EDIT: I know a fuse has blown for my Cigarette socket, could that cause it? Thanks
seat_tux
Mine was a dodgy solenoid. I'm still waiting on the garage ordering in the part.
lc_allan
Northern Monkey
Sep 15, 2006
3,389
If you can hear the solenoid moving then it will probably be the slider not connecting with the handle.
Check this thread:
http://www.seatcupra.net/forums/showthread.php?t=114846
Before removing the trim, lift the S handle and give a few hard taps above it on the boot. It didn't work in my case as the handle mech was stuck up but it may loosen it.
kineticz
Forever moddin'
Jul 23, 2008
1,958
Shropshire
