SPL readings and carburator flow arecompletly different kettlr of fish to forced induction (turbo cars).
The MAF does have a grill before the actuale sensor to 'straighten' the airflow and its part of the actual MAF itself.
So... removing the trumpet will have no "negative" effects right?![]()
I would of thought not, Mike.
Considering I have a open cone filter straight onto my MAF and I have no problems![]()
Oh yeah!On another note, do you know what size the vacuum pipe is that goes into the top of the DV? I need some more as mine keeps splitting a bit as the Forge one is slightly bigger than the OEM one!
i have some left over how much of it do you need?
if u was despertae for it you could of come got it as i wont be using any of it for a while![]()
just seeing if your going to the RR day would like to see if you had got any gains from your airbox mod![]()
Well, I have been away all week (went to Rome with the wife and my mum) and when I returned yesterday there was something waiting for me... my latest mod for the FR!
I bought it off a member on this forum and it should transform the handling of the FR.... Any ideas?![]()
Whiteline arb?
Whiteline rear ARB?
You said it, so i'm guessing the same as above
What did you cut your splitter with, if you use a hack saw doesn't it leave the edges rough? or do you sand them after
