Engine make a massive difference to the whole car. Probably one of the most noticable and best mods. I will be doing mine come summer.Might be something to look into then!
Did you notice much difference with yours?
I dont think anyone does uprated mounts for the MK4 Ibiza TDi as of yet? However if there are some, I will have to let my mates know as they all drive TDi's
Had to bring this up...no you didnt!
Dont think I have a phenolic gasket fitted. To be quite honest dont know what that is but will find out.Do you have a Phenolic gasket fitted to your car.
These are very thick and a very good heat barrier between the head and the intake manifold, this might have helped you today.
not bad figure though.
What were you expecting?
As brad stated the test is run in 5th.Is that the standard gearbox/ratio's in there?
28mph/1000rpm is really low for a diesel, its almost petrol-like.
Unless of course its in 5th, not 6th? (I'm presuming "gear selected: 6'" means its in 6th?).
hehe long thread now heyfair lay , took all day to read !!
some inspiration there,
my clutch is slipping a bit under load if planted , from low down, so am thinkin is it best to get a SMF converion done at the start and what was the sachs clutch you have?? - from AMD ???
i think i need the organic, and not sintered, but i do plan on hybrid down the line,
i am also thinking off the SFS kit , or just the important ones, for now,
right must get back to wrok now!!
Dont go for Sintered it will drive like a dog on the road. If its a track day car then cool. Also I wouldn't go for single mass. On Diesels they are awful - my "judder" is not the DMF its the map that needs tweaking.
As for SFS I would go for Pipe no.4 and TIP.
If the car was petrol, I'd be looking at the graph thinking the ecu was pulling back after it hit peak torque.....
