removing the battery
jay-bob 25
235
hi can anyone tell me if it is ok to remove the battery on the 2008 leon fr without effecting anything , do you have to have a code for the radio?
floridafil
53
North East
Code is NOT required.
The radio automatically identifies "its" vehicle.
If the electricity supply is interrupted, when the ignition is switched on again the radio will check whether it can still identify "its" vehicle.
Once the vehicle has been identified, the radio is again ready for use.
MJ
Public transport abuser
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
you wont need a radio code but you will need to re-calibrate the steering angle sensor - once the battery is re-fitted take the car on a short drive and the lights on the dash that appear will go off. also the alarm may go off when your removing it, to avoid this noisey problem just leave the ignition on when doin so.
binkylad
140
northern ireland
just on the point has anybody ever tried that gadget (cant remember the name) that plugs into your cigarette lighter with a battery attached which keeps current flowing therefore dont need radio codes or need to reset anything? just wonder if they work?
MJ
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
Depends if its one with a battery built in or its a battery pack with a connector, the best are the battery packs with a connecter because you plug it in to the cig lighter so the power is never totally lost - thus saving the power/radio etc
DanGB
Who need's a Diesel....
Feb 12, 2006
3,772
London
The only time you will need to reset the radio code is when changing the instrument cluster or doing stuff to the immobiliser.
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
yeah there pretty good used one a few times, did what it said it does :)
