Scraping Front Lip/Bumper
daboy3000
No Longer a Seat owner
Jul 2, 2008
710
Oxted
Just drive real slow over bumps or out of driveways etc and you should be fine but i still scrape mine a couple of times a week.
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
Just under £20 from the dealers; if you have a cupra r then they are easy enough to fit; remove your old one starting at the edges working towards the centre. When attaching the new one, the two lugs in the middle will benefit from some fairy liquid and a trolley jack; you'll understand what i mean when you come to do it. If it isn't a cupra r, alot of people use self tappers to attach the splitter to their bumper.
stevo lcr
75
Tividale
I find it funny when it scrapes,and people look at you thinking you must be mad scraping the underside of your car,and you drive off as if nothing happened!!!
Faisal
UK's 1st Liquid Yello LCR
May 27, 2008
1,445
Most likely at work
haha true,but people stare at me as if im retarded when im going over bumps slowly,and at an angle, or even when im swerving to avoid the potholes in glasgow that a double decker bus can fall 10 feet into...
DannyC87
Mar 4, 2008
3,459
you should see the looks I got when boarding the Isle of Man ferry; had to go full 45degrees and still just scraped :(
