I second what he said but anywhere you can find a clean metal connection pint will do fine . have a look under the carpets you may find an earth point off somthing you can tap into there. dont quote me on that though.
but why put the amp in the passenger footwell anyway you doing a cutsom build.???
so its for the front components. i did think about that justr after i posted that message. well do you have to use a power feed from the battery to run it like you do with subs? if so just feed it back through and use a point in the engine bay..
The battery isnt actually the strongest Earth point, bare metal is, so anywhere under the door trims or in the footwell, scratch the paint off then stick a phattt bolt through, cud drill a hole as long as u know nothing is behind
