Oily crankcase fumes in the inlet charge are not ideal, but on their own would not cause too much difficulty.
However, downstream of the crankcase vent lies the EGR valve, an automotive kludge to comply with NOx regulations by injecting an inert gas into the inlet to reduce the oxygen content at the point where combustion temperatures might rise high enough to form NOx. This action increases the soot formation, and is the cause of the sooty blast you see from diesels accelerating away from the lights, or on joining the motorway.
The only convenient source of an inert gas is the exhaust (most of the oxygen is used up already) so hot sooty exhaust gas is added to oil-mist and crankcase vapours, forming a stiff sludge that bakes on, gradually chokes the inlet manifold and eventually stopping the EGR valve from closing when it should, triggering limp mode and much bad language.
CCV bypass (an oil catch can) is relatively easy to do and will reduce the sludge formation. EGR disabling is also easy to do, but recent cars will detect it as a fault and light the CEL.
TornadoRed, you are apparantly writing from the USA, where "low-sulphur" fuel was until recently 500ppm, much higher than European low-sulphur. However everyone is now moving on to ultra-low-sulphur, 15ppm or less, the US just a bit later than Europe.
However sulphur in fuel isn't responsible for soot, which is incompletely burned fuel, a result of poor engine management. Sulphur in diesel fuel interferes with particulate filter regeneration, which is why a move to low-sulphur fuel is required before any further reductions in particulate emission can be achieved.
