Hi
As a cheap alternative to trying to find a downpipe & decat that fit properly and dont cause error codes; would there be much to be gained by buying a second hand cat for the ibiza cupra, gutting it and swapping it over with the original cat (till MOT time obviously)?
Does the downpipe also form a large part of the restriction?
Would the sensors on the cat throw up the same faults as per fitting an aftermarket decat where you have to have a nut welded onto the pipe in order to lift the lambda sensor out of the exhaust flow?
Let me know if you think this is a worthy idea or if I'd be wasting my time
Please nobody tell me I need to get a sports cat - I'd get one if I had the money, and besides it's not much of a problem getting under the car once a year to swap a section of exhaust.
Stephen
Stephen
