Like im going to name names![]()
"Health & Safety is the responsibility of everyone, if a hazard or danger is noticed it should be reported immediately"
dont cut springs........ lowering springs are ok, best of with coillies, ive seen a set on the bay for about 210 quid, dont know about quality so dont quote me on these.....
http://cgi.ebay.co.uk/COIL-OVER-COI...14&_trkparms=72:1301|66:2|65:12|39:1|240:1318
Everyone always says coily's coily's coily's, but unless you need to set your car up specifically to height or weight requirements there is no need.
You can get spring clamps.
Thats the cheapest way. Deffo break sometime and damage something.
I had spoken to someone a while back about spring clamps also.
These are primarily used by vehicles towing caravans, and only fitted as a temporary solution to serve this purpose.
Therefore, for the 'long term' task of stiffening the suspension/lowering the ride height to help remove excessive roll around corners, these might not be a safe alternative to lowering the rear.
What about the koni strt kit: http://www.dpmperformance.co.uk/koni-30mm-strt-kit-ibiza-6l-0402-p-2275.html
Ive heard good things about them, quite fancy a set at the end of the month!
Anyone got any experience with them?
Cut the springs?![]()
