Lights Dimming & Heating
mcculloch
SEAT LEON ST FR 2.0TDI
Mar 25, 2008
134
8
Kilmarnock Scotland
Hey,
I have a 55plate MK 4 Ibiza. Just recently when you start the car the digital heating screen flashes 5-6 times then returns to normal. Also when you turn the wheel the dash lights and headlights dim slightly then return to normal? Anyone help me out?
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
The climate control flashing means you have a fault or it needs re-gassing. Mine was flashing so took it to dealers and they replaced a pressure switch and re-gassed under warranty.
The lights dimming is normal when turning the wheel while stationery or at low speed as the electro hydraulic steering pulls a lot of current.
mcculloch
Mar 25, 2008
134
8
Kilmarnock Scotland
Cool thanks for the quick reply. My warranty ran out last month. Do I need to get it regassed,? I dont use air conditioning. How much will it coist
ross p
Back at last....
Jul 13, 2007
467
Glasgow
www.firstrespondernm.co.uk
Hey,
Not sure about the digiital heating display
But the dimming of the lights are normal, there was another thread on it a while ago. So nothing to worry about:)
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
As said the lights dimming is normal, the Climate control sounds like it needs a re-gas (Kwikfit do this quite cheep). The fact that you don't use it could well be why the gas has gone off, the gas needs to be pumped round the system and exercised once a week.
RUM4MO
7,970
1,060
South Scotland
The thing is that even up here (up North), the A/C is handy to speed up the demisting in wet weather - and West Scotland tends to suffer a bit of rain now and again!! If a pipe is broken and a lot of moisture gets into the system, then fixing it after a few years will be expensive - something to consider if you plan to trade it in some time in the future, ie its value will be lower than it could be!
RUM4MO
7,970
1,060
South Scotland
Just remember the main location for leaks due to under use will be the compressor - and in these cars the compressor runs on bypass or low duty when not being used to chill the car - you can not deselect the compressor - so not using it should not cause any problems unless some of the coupling seals are a bit stuffed due to other reasons.
Keef83
76
Maidstone
On a simular note, has anyone else noticed that if you have the AC on and then put car in Reverse the AC seems to get a boost?
Oct 17, 2006
2,141
Mid Wales
The system automatically goes into recirculation mode when reverse gear is engaged to try and stop exhaust fumes entering the cabin - it does it on the standard A/C models too
jeb963
Hi mate, mine did this flashing display thing but only ONCE, system works ok but must confess that the fan speed seems to do its own thing in ECO or any other mode. GOT my car serviced at a VW dealer as a mates wife is on service desk, they say it indicates that the air con is low and needs re charge. Is it worth me puttin into stealers as its under warranty till april ? You suggest if there a fault they will re gas ?
kriso
Jan 29, 2007
2,325
Brighton
Mine didn't flash every time, just every now and then. I ran Vag-Com on it and it came back with a 'A/C Pressure Switch (F129)' fault so I knew there wa a problem. They probably had to empty the system to replace the switch so would have had to re-gas it. It's worth taking it in, but try and run Vag-Com on it if you can.
jeb963
Have a mate in the right place, mine flashed but only once ( 5-6 times) so took it to him. He ran a diagnostic . If it only flashes once/or twice it is the compressor sensing a 1 % drop in pressure and it is telling you to have it re gas'd. It it flashes regular it is a system fault probably a pressure switch !
