Anyone got Bluefin?
Stupra
237
West Yorkshire
By the way, Andy from Awesome said to me that Bluefin is not a good match, should you want to install a high flow cat/downpipe.
So it looks like a cat back system for me for Christmas then!!
Emailed Superchips yesterday about that and had this response (they are doing stage 2 maps soon)...
[me]Hi, does a different exhaust require a custom map or does the standard map make more power with freer flowing exhaust / intake. What about the fuel pump - can the map be changed to take advantage of uprated internals (as the fuel pump is the limiting factor in midrange power).[/me]
[superchips]
Yes it will need a different map. We have an Ed30 DSG in tomorrow to finalise our Stage2 conversion for the 2.0 T engine as used in the Cupra/Ed30/S3 for cars with a full system will benefit from this revised map. If you’re going down the fuel pump route then I’d advise an APR pump and then we can revise further to provide higher boost in mid range and up top as the original pump can’t deliver the required fuelling for much higher levels of boost.[/superchips]
