borntodj
Hi, does anyone know the part number(s) for the Sachs uprated clutch kit for the PD150 engine? I've searched the forum but haven't been able to find any part codes.
Danny
Danny
i assume the sintered one is better than organic ??
Organic is much better then sintered.
What`s unreliable about fitting a hybrid turbo to a PD diesel? Sachs do a organic clutch rated at about 400 lb which should be good for road use.
I'm on the verge of replacing my clutch with the Jabba Sachs option with the single mass flywheel (the car has done 70k miles on a Revo map, 40k with a high friction "allards" plate and some considerable judder from standing in 1st gear only - not under any other loads through the gears though) but I am concerned at the potential downsides of the SMF vs DMF.
