Ok cool! Got my MAP pipe off without removing the bumper and headlight! Took the fog light grill out and managed to get my arm in there and undo the second jublee clip on the rubber coupler. Drilled the heads off the bolts and removed my MAP sensor, seems to be 12mm which sounds right for amk lcr. Willy what size is the hole in your pipe? Could you post the dimensions for the pipe? Did you have it in place? Did it fit without any other silicone bends and such like? Cheers
