Central locking: One door sticking, advice please
Atlantia
127
The South West
When I lock the doors with the remote, the drivers side back door is trying to lock but the little plastic pull thing isn't going all the way down. Its really stiff to push down by hand as well.
Any ideas where to start trying to loosen it up/fix it?
Many thanks
bai_ILIA
I've got the same problem. It all started from the right side (2-door TDI sport) and now both sides are not locking right away. You need to use the remote several times to lock it properly. That is why I am using the key...I think the problem might be with the central locking device located in the boot? Any suggestions?
Atlantia
127
The South West
Hi bai_ILIA
Have you noticed a pattern for when yours malfunctions, or is it all the time?
Mine doesn't do it all the time, but it seems to do it when I driive home from my girlfriends place.
The thing is, thats a 20 minute drive, after dark, lights/heaters/radio/wipers etc all on, and I tend to not see any other traffic so I just take it very easy and drive nice and slow and steady 30-40mph all the way. I get home, turn everything off, and it does it.
Next day, once the battery's recovered, its fine.
I think this might be a question of charge in the battery.
Can you check yours next time you go for a daytime drive with no electrics on and see if it makes a difference?
Gene
bai_ILIA
Mine started several months ago. First, the passenger dooe, now both. The problem occurs all the time regardless of the conditions. As I understand this is a common VAG issues - troubles with the central locking system.
bai_ILIA
I am pretty sure that it is the central locking mechanism located in the luggage compartment. It takes 3-4 clicks on the key to lock it. It is possible that a hose is loose or something is not right.
Jordan20vt
Mk3 20VT
Jan 14, 2006
256
Rugby
i also have the same problem, drivers side will lock and unlock sometimes and other times it won't to either. very eratic.
Anybody know of a solution?
nutty_merka
72
trusss me. happens to me aswell F&^*in annoying if u ask me. im gonna try spraying the mechanism with wd40 to see if that helps abit though. also key fob is flippin up abit gna try buyin a new battery or fob :think:
