Im looking to up the power in my cupra r.i have a bigger turbo and custom chip in mind.the garrett gt28rs is the turbo im thinkin of going with and a custom chip.Where is the best place to get a full turbo kit or if anybody has any better suggestions on
how to gain bigger power are all welcome.Thanks
have you factored in all the costs?
do you have an FMIC, 3" downpipe, full exhaust including race cat, air filter etc?
the standalone kit from Jabba (last time I looked) just included the turbo kit and the parts to fit and map this, but did not include aspects such as the FMIC (which is at least another £500 on top of this install) and this is a must to have due to the massive amount of heat soak that will be endured from the big turbo
also have you modified the handling on yours i.e. coilovers etc, as you are really going to need to up the handling to cope with the extra power
also the engine mounts and dog bone mount I would highly recommend changing due to the engine lift and extra strain on the standard mounts from the hike in power
most importantly, what is your target power? if you are thinking of going for a GT28rs, then you will have to peg the power at around 330bhp to ensure the engine does not go pop. Standard internals are only good for 350 absolute max
anything more then you will need to look at uprating the internals which is a few more pennies......
lots of things to consider going Big Turbo
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
