Should I have a fuel cap release?
Wastegate86
black mk3 cupra
Nov 3, 2008
73
East Devon
only got my cupra a few weeks ago but a little bit confused about the fuel cap??
is there supposed to be some kind of release button as mine has nothing not even a key lock on the inner cap
so any dodgey pikey off the street can go up to my car and take a piss directly into my fuel tank!!!:ban:
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
its supposed to lock with the key (when all doors are locked). you should see a little hole with a metal pointy thing in it to the bottom left (i think) and that should go into a hole on the petrol outer door thing..
mine doesn't work, but used to work fine on my 1.4..
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
open the flap / lock the car
now watch inside to see if a peg pops out and then back in when you unlock
that peg locks the flap down when the car's locked
knew an Espace driver once that broke a very expensive fibreglass rear 1/4 panel just 2 days old not knowing how to fill up with fuel and used brute force instead :):)
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
ok seriously wastegate I understand your problem. Hell mine has not worked since i bought it. But lets be honest how often does a pikey really piss in someone's petrol entrance? Even more so, checking all cars to find one thats unlocked...hahaha
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
oh dear no peg on mine!!!
any ideas if it can be fixed?
with the doors locked too ?
usually a knackered lock solenoid so if you really wanna fix it strip out the rear 1/4 trim and replace it
just don't swear at me when the next one breaks but outwards and jams the flap shut solid :p
Wastegate86
black mk3 cupra
Nov 3, 2008
73
East Devon
ok i was taking it to the extreem about the pikey piss thing but its just a litle worry
oh well if its a common fault and not an easy fix then ill probably just leave it
cheers chaps :)
