Well,
Looks like I've found out my suspension problem that's been causing mischief for quite some time. Had the car looked over and the rear axle beam has a slight kink, causing the rear camber of the wheel to move in the direction of the strut. So basically the wheel lies at an angle with the top of it closest to the strut. We think that this, over a short period of time, has caused the front wheel to mimic the camber of the back? Is this idea feasible? The inner of the front tyre has greatly worn down.
We are planning to replace the rear axle beam. This will obviously straighten out the rear camber. But do you guys think the front will straighten back out as well following the newly straight rear wheel camber?
Many thanks for your advice.
