I have searched the topic before you say anything, just wanted to see if anyone could clarify a few things, on the earlier leon models 2000 - 2002does anyone know frequency of keys i should be looking at getting.
AFAIK the 433/434 is only rounding anyway and the difference doesn't matter. I never bothered checking, so it could be just luck mine worked I suppose, but I was under the impression it didn't matter.
Hi matey, I got a flip key & blank blade from fleabay - got the blade cut at Tipmsons for 7 quid and then just replaced the transponder from my old key and reprogrammed it as per the cars manual. Worked fine and also works a whole lot better than the original 2 button key
if you have the old key then yes you can use the OLD transponder out of that, if not you will need to reprogram the ecu for the new transponder. either a good locksmiths can do this or your seat Dealer. make sure though you have the correct transponder.
