200bhp
T. Spark
oh na a full zorst on tdi makes them stupid loud mine was 99 decibels before i removed the cat;)
The cat isnt there to silence sound, so should still be that, with or without. Sounds about right for a full exhaust with no silencers as mine produced similar results earlier this year
So £550 for a td2 turbo if I was to exchange my 150 turbo?
And then a map on top, so roughly £850 ish not inc labour for turbo fitting.
I generally find that a map to suit the TD2 needs abit more work, so budget a little more for the remap, but yeah basically :)
APNess
171
Not seen any mention of a methanol/water injection kit? Is there something I'm missing here (like, do you guys know something about 'em that I don't?) I'd have thought with a remap and a meth/water injection you looking at 200hp easy, prob a bit more, and more torque, just have to remember to pack meth/water top up in the boot when your washer bottle light comes on :)
This is on 'my list' after the clutch is sorted out, can't do anything till it's uprated unless I want to kill off what's left of the current one.
Feb 1, 2007
1,602
Nottingham
Not having the cat will make it noisier (not stupid though). I used to run a Milltek resonated cat back system. Now the decat pipe's installed it is louder than previously.
Stinky
Have you noticed a reduction in smoke output since the decat has been fitted?
Does the turbo spool up noticeably quicker with it fitted?
Glynn
mihaib
Alba Iulia,Romania
I removed the cat too on my FR TDi and the noise isn't a problem,even with a straight-through rear silencer....on the downside,there's a bit more smoke and less top-end power and torque(just had the remap redone for that:whistle:) ...on the upside,the turbo spools up a little quicker thus the engine responds better at lower rpm and the sound when lifting off the throttle is great:lol:
