Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
Is there a how to remove a door card on a Leon Cupra R the only one I can fnd is very different to mine, I don't want to start prising off door handes if it's it's the wrong method
The worse bit is popping off the pull cover. As recommended (by pat) I would suggest levering on the underside of the seam as you can mark the plastic slightly. Just take your time over this and the rest is easy. You do need a bit of effort popping the cover off.
I helped someone recently replace a Mk4 golf's door cards with leather ones and I used a small knife on the underside then a small screwdriver and it hardly marked it at all so will do the same
