New bits for operation STIFF
2 x Inner CV boots with cv grease and clamps 1K0498201A
12 x replacement bolts for inner cv joints N90991102
6 x locking tabs for inner cv joint 443407357B
2 x front LCA bush 1ML407182
2 x bolt N90484003
2 x rear LCA bush bolt N10262201
2 x nut N0150816
2 x front strut rubber bush 1ML412331
2 x bearing 1J0412249
2 x rear strut top mount bush 1J0513353G
4 x bolt N90648401
2 x rear strut lower mounting bolt N90517302
2 x nut N10286110
2 x front strut lower bolt N10207803
2 x nut N10106402
1 x coolant header bottle 1J0121403B
1 x coolant tank cap 3B0121321
2 x 1.5L coolant SG012A8FM1
4 x front caliper carrier to strut bolts N90708504
4 x rear caliper carrier to strut bolts WHT003250
2 sets of brembo caliper seals 1ML698471
brake pipes for brembo's left 1ML611735
right 1ML611736
16 x wheel bolts (20?) WHT001812
4 x disc retaining bolts N10648301
Engine mount bolts N 10268302 x2
N 90597001 x1
N 10209603 x4
N 10246604 x1
Track rod ends 8N0422811A/822A
2 x outer CV joints
We ordered all this bits today for David at Seremotors, it has been a pleasure so far to deal with him (which is never something you usually say when you deal with a Seat Dealer).
Next on the order list is R32 23mm ARB, bushes, screws and clips and Audi TT Roadster rear LCA bushes. These will be ordered tomorrow.
Hopefully these bits will be fitted in the next month or so.
So plan is to drop the front sub frame, buff and paint it. Replace all the bushes and bolts from it. When this is off fit the R32 23mm ARB.
The strutts and hubs will be buffed and painted aswell. The top mounts will be changed at the same time as I'm still getting a dodgy knocking noise and suspect these.
These were changed recently with GSF one which i have since found out are not for the LCR!!!
So new tracking rod ends, top mount bushes and bearings, LCA bushes and ARB bushes and if the problems still there it'll be a tin petrol for it
Once all of this is fitted I'll get the 4 wheels alignment done and the back roads will be blasted
This is all to get my car ready for track days next year.
As everything is being replaced this will allow me to decide which direction I want to go with in the suspension, coilovers or just springs and shocks
