What do I have to run without the N75 valve?
PS. Thank You for the quick reply!!!
Leave it plugged in electronically.
Hose from charge pipe to mbc.
Hose from mbc to actuator.
Put a tee in the hose from the charge pipe to the N75.
Put a tee in the hose from the N75 to the actuator.
Put the mbc in between these tees.
The MBC has 3 connectors, where do I have to connect the 3-rd pipe and in what order should I connect them?
Alot of money though, but a one off for sure!!
And its got to be paired with white wheels
DO IT!!!
Those pics must be tempting you away from the green, looks so fresh.
