Check this out chaps - Plus he is a Cupra owner!!
http://www.detailingworld.co.uk/forum/showthread.php?t=54411
i've always used meguiars stuff with reasonable results but now i'm thinking about moving onto better products. in the past i've used megs deep crystal paint cleaner prior to a couple of coats of NXT wax. the paint cleaner always left a really smooth finish, is this an alternative to using a clay-bar?
i'm think about trying some dodo juice diamond white wax and dodo juice lime prime as a pre wax cleaner. either that or invest in some megs clay bar and get some zymol creame wax.
Yes, it's perfectly possible.
While possibly not the best way of doing it, T-Cut certainly can bring it back up. If you're careful and don't wipe away through the clear coat on the metallics then you're simply removing stubborn dirt and light swirl marks. This will bring the paint back somewhat.
Of course, you can only do these a few times before you're down to primer
