::: PART 1/2 ::: (Due to Pic Limit)
OK fellas... here I am ...
A little man in a little place on the other side of the map...
With BIG news for you all.....
As I mentined, I went to Citroen and got one nozzle as a Guinea Pig.
These com from most of the current Peugeot and Citroen models.
First of all the LEON nozzle is longer and flatter, and the one side has an L-Shaped rubber hose.
This rubber piece will have to be substituted for a small flexible pipe on the new Nozzle.
Not only does one of the jets use an L shaped rubber pipe but also has a skew leg to fit there.
So the mains
Problems are :
- 45º Leg on the Leon Jet
- Small pipe needed to substitute the OEM L-Shaped pipe.
- Larger hole and no fitting clips in the PSA Jet.
Solution :
- File the PSA jet slightly on both sides.
- Get a short flexible pipe ( so pressure wont acumulate on the L shaped hose)
- Fit the jet a little further from the window and it will have to be glued in place.
Pics :
Please excuse the mud, car has been in the workshop for a few weeks.
PSA Jet.
PSA Jet vs. LEON Jet :
L-Shaped Hose.
(This hose will have to be substituted for a straight flexible one.)
It is only present on one jet, as the other has a T-Piece.
