paint at window seal peeling off on door
bhoyo!!
hi there any1 else had this problem?? the top of the door at the window seal on both doors above door handle at corner the paint has flaked off right thorugh to the bare metal and has started to rust and paint seems to be flakin off more and more i have tried touch up paint but making matters worse i have used black pemr marker to stop the rust for now, car is A 54 PLATE!! also i get noise wen at high speeds as if the window is open but aint
TheCraig
Scaramanger!
Mar 13, 2007
80
Tyne and Wear
Did you get this sorted? The car should surely be under paint warranty?
The paint started to flake on mine where the rear quarter panel weld is (top right hand corner of the boot opening). Fixed temporarily with touch up paint, but it'll be getting sorted before the winter!
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
I have the same problem next to driver side rear window, bottom right corner. But its only the laquer that has peeled off. I've been told its a rear window out job and it will cost a bit as the rear windows are bonded in and will require cutting out. Been advised to just put some clear nail varnish over it.
bhoyo!!
yes had it looked at been told both doors need full respray :cry::cry::cry::cry::cry::cry::cry: sucks big time scared to get a price
DIFT
Torquing all the Torque
Oct 8, 2004
1,546
Kent/London
Is this not covered under the warranty??
Mine is in currently with the same problems. 54 plate cupra
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
I've just noticed a small patch of bare metal at the bottom of the drivers door window seal :( What's the best way to fix this? Touch-up pen?
DIFT
Oct 8, 2004
1,546
Kent/London
Ive still to get mine done at the dealers (as the spray guy was away before christmas), but mine shall be going in soon.
I would try with your dealer again, or try another. Paint should not come off a 4 year old car to leave bare metal.
My dealer had the SEAT/Audi paint specialist to have a look at mine, and it turns out I have very little--->no primer on my doors!
If I am getting mine done under warranty, I don't see why you can't.
