Airbag light stays on for a few seconds when car started
Bush020773
Hi everyone,
I am new to this forum, would like some help please. I have just bought a ibiza mk4 1.4s 53 plate, and am not sure about the "airbag off light" coming on when i switch the ignition on, because it only stays on for a few seconds is that normal or is there a problem? The key switch in the glove box is set to on anyhelp would be gratefully recieved thanks.
NickyJam
FR - gone, not forgotten
Mar 17, 2008
1,669
SW LONDON
that is normal. the light will turn off when the airbags are inflated to a point of pressure, meaning that they are in good working order. If the light stays on continuously then you may have a faulty airbag.
the only time you'll need to turn the airbag off is if you ever carry a baby seat in the passenger seat (for safety)
mixupz
Just call me Rash-MIX
Oct 5, 2007
1,538
Dirty South East London
I posted this exact same question quite a while ago, i got a good hundred views and no one responded so i assumed it was either a stupid question or an unknown fault with no resolution...
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
That is class :lol: Where did you get that info from :shrug:
The air bags are not inflated with air as such, they have an explosive device in them that is set off with an impact, the delay with the light going off is the cars electronics doing a self check of the airbag system and it takes a second or 2 to complete the check
NickyJam
Mar 17, 2008
1,669
SW LONDON
there is an explosive device in them but they are inflated slightly at first. that is the noise you hear when you turn the ignition ;)
but i believe this is only for the driver and passenger airbags as these are the primary points of impact upon collision, hence, more important
NickyJam
Mar 17, 2008
1,669
SW LONDON
correct. but there is also an electrical noise which is the general check up carried out before the airbag light goes out
i may be wrong but when i first got the car i tried to work out more or less what was happening when the noise came up :lol:
Nath.
Jan 1, 2006
8,620
16
As said it's the fuel pump priming ready for you to start the engine (OR) the climet control air direction flap finding it's correct position on it's stepper motor
there should not be any noises from the air bag system as it's all solid state electronics and a (rocket booster):D
NickyJam
Mar 17, 2008
1,669
SW LONDON
:lol: thanks for clarifying Nath, i wondered this for ages then came to my conclusion...obviously not the right one :thumbup: most probably the air flap you're on about
mixupz
Oct 5, 2007
1,538
VERY GOOD! turbos are soo intriuging...most of what i know about mechanics i learn from that site....although its not reccomended when your on a deadline its easy to be distracted to read other articles...i.e. conspiracy theories :yes:
muddyboots
Still hanging around
Oct 16, 2002
5,739
And when they do go off, you don't hear/notice the airbags as whatever you hit makes a much louder bang and you've probably shut your eyes. Well I did anyway :D
lex26
Hi guys
I have the same problem. After reading your answers they put my mind to rest for a bit, but then I looked into the owner's manual which says:
"Ensure that when the ignitions os switched to the 'ON'position, the 'AIRBAG OFF' warning light does not come on."
Any ideas?
