MK3 Cupra Part Numbers
undefined
Complex Simplicity
Jul 8, 2007
125
Sheffield
any 1 know the part number for the cam shaft position sensor and weather or not its definatly the sensor next the the belt when cover is first taken off..right in front of your eyes?
cheers
C_u_p_r_a_m_a_n
Hello...What is the oem fpr for the AQX engine? Cause in the 1st page it is written that is 4bar but in Etka sais it's a 3bar fpr with the code 037 133 035 C. And also the car is used and recently bought and has 3bar fpr. Also it has a maf with code 06A 906 461 L (same maf from MKIV Ibiza FR/Cupra) and in the 1st page it is written that the oem is 06A 906 461 D. Further it has N75C and not N75F. What is going on? Everything is different! LOL
C_u_p_r_a_m_a_n
OK. Can you give me the oem part numbers for the maf, n75, coil packs and the fpr? Someone with an oem MK3 Ibiza 1.8t. Help please.
C_u_p_r_a_m_a_n
Open your eyes and read whats already been written in this thread
I read the thread and already said that the part numbers are different. But PhilW wrote that these part numbers are most common and not oem. I need oem part numbers. And also i suggest you to write with a more proper way. In your language open your eyes and read what i wrote.
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
Stick down your kebab and read about your car before posting about what you know nothing about. Your car doesnt use a 4 bar FPR, The N75C and F are EXACTLY the same and the MAF part number will be on the first page, if you have the wrong one on your car then get the right one
Next time just search
You can now pick up the kebab again
C_u_p_r_a_m_a_n
It's not my car. I have a MKiv and i know what my car exactly has. C anf F are the same? Hmmm. Right. Anything you say. Who doesn't know here? :funk:
Dec 3, 2007
2,475
cardiff
now now girls. myki stop biting. cupraman why dont you just go to the dealers and ask them if its oem your after. or down load etka from the internet and have a look for your self. the numbers you require in here are correct and if not someone has updated somewhere. you dont just have to have oem, i know you think that they are great but the part you get from the likes of euro car parts or simlar will be the same!
MichaelMr
Hi,
Does anyone have the part no and/or size of the exhaust back box heat shield screws?
Also need part numbers for a full set of headlight (front) bolts and full set of front bumper bolts.
Also, did anyone confirm that the parts list and no's (1st page) for the cambelt & water pump would also suit an AYP.
Is there such a thing as an uprated/higher spec Cam belt?
Thanks.:D
