Where is this coolant manifold on the diagrams?
I had an AMK Engined LCR. Over the 4 yeas I had it the Coolant Sensor went first, I replaced with a green top (rich running), then the prongs scaled up in the header tank (three beeps).
Then I had the gauge go funny. I did a load of reading and found it had a diferent sender unit, can't remember the links now. Whilst it was still funny, I was on a RR day at Awesome. Jim commented that the gauge was funny, that it was a common fault on the 1.8T and that it was a fairly big job because of the position of the sender in the thermostat housing which is under the inlet manifold, LH Side (from the front) and because you had to drain the coolant. Car was due for a service anyway, so I let the garage do it. They confirmed it was a big job as they had to drop the coolant.
Whatever. If your gauges are duff, change to a green top and see if it fixes it Much easier job to do the green top, and it doesn't matter who's right or wrong if it gets fixed.
