South Wales Cupras Chat
Status
Not open for further replies.
Dec 3, 2007
2,475
cardiff
well i thought it was something to do with starter but couldn't see any thing at first. Well the car is up and running. I bled the clutch and it feels nice and bouncy so my mum says. She was my pedal pusher. I need to pick up my gear linkage from audi tomorrow morning and that should take 5min to fit its just getting all the gears again lol.
How do i go easy on a clutch. Dont batter car around every where?
Dec 3, 2007
2,475
cardiff
will do. any idea how many miles roughly? just want to be sure. i hardly welly it any way. only when im feeling frisky! lol
Dec 3, 2007
2,475
cardiff
strange how he got limp mode though! wouldnt have thought it would of made that much of a difference! maybe i should try the j valve!
rhysox
Ibiza Cupra 1.8T
Jun 18, 2007
438
Cardiff
oh god, i think i needed to reset the ECU or something. it must've been 5psi as it was still spooling but no power at all. pulled into texaco just before a48 and changed it over then. was back to full boost :D
Dec 31, 2005
1,856
London
about 100 miles is alright to bed it in.
need to do some logs to sort mine out, even if i end up giving it to a garage to sort out it would be nice to know what it was first ie boost leak etc
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
not far at all, met plenty of the boys from stroud in the past, half hour blast from cheppo
sadly dont think the trial version is much use for detecting a boost leak cos you cant log actual vs requested
though myki might be willing to help with that
Dec 31, 2005
1,856
London
im just guessing at a boost leak, its running rich and going into limp mode occasionally in 4th/5th and has had 4 new coilpacks, a maf and a pre cat lambda.
before i fitted the lambda it was running like ****, misfiring and running lean, but now it runs fine for a while and then again after code is cleared.
Status
