lowering springs noise
owen lcr
orvil
Oct 10, 2006
1,179
montrose, scotland
hi folks, i lowered my car a few weeks ago and noticed a creaking noise coming from the suspension when i turn the steering wheel when going slow, i think it must be the new springs turning on the suspension bases but i dont know how to stop the noise, i thought it would go away after it had bedded in but it still does it... any sugestions that may help are much appreciated..
the springs are H&R, i am very inpressed with the look and handling but just the small creaking noise is starting to annoy me now
cheers
ents
71
Tallinn - Estonia
work fine for me with FSD Konis. Are you sure thery're not upside down as they are progressive springs. Or maybe they are not correctly fixed in their mounting plates (not sure its the right term).
owen lcr
orvil
Oct 10, 2006
1,179
montrose, scotland
you are right as they are progressive springs, should there be more coils at the top or at the bottom, i was not to sure as i didnt think it would matter
help is greatly appreciated
nighty
any pics of your car lowered if thats it in the sig it looks sweet.
pr0ton
Newbie
May 28, 2006
127
cheers
I have this exact same problem. Changed the H&R's last weekend and they're creaking when turning the steering wheel at slow speeds.
Did you have somekind of transparent tubes around the front springs upper and lower first 1,5 revs? I thought they should be removed, was i wrong??? Some of my friends thought that i have tighten the top strut nut too much and the axial bearing is making that noise. I tried to loosen the nut and tighten it a little less, but no change. If the bearing is already broken you can only fix it by changing them.
edit: i also wasn't 100% sure which way the springs should have been installed. I installed them with more coils at the top, and the text on the coil upside up.
GrantyBoy
64
Aberdeen
interesting. Mine creaks at low speeds -15mph and I'm standard OEM springs. Wonder if this could be a possible issue???
tommy-cupra
380
Prague, Czech republic
cheers
do you have pictures with HR???
pr0ton
Newbie
May 28, 2006
127
Quote from H&R website:
"When the spring is fitted the stamp markings on spring should be readable, i.e. not upside down. "
DEVIL
Hi guys,
If it were me I would put some castrol red rubber grease in the top shocker cap and maybe a little on the bottom of the spring but when i say a little i mean a tiny bit.It use to cure this kind of problem years ago when i was in the trade.
hope this helps M
jamfool
Search + Read = ANSWERS!
Aug 15, 2005
37
Nottingham
I have this issue too, only had it lowered for a couple of weeks on the H&Rs and it was done by JBS so i have no doubt that they've been installed correctly....:confused:
the old man
55
my standard set up also make this noise at low speed.
I intend to get this checked at next service.
Looking on here I saw a thread about steering rack problems that produces this noise at low speed. Apparently this was an issue with A3s and golfs that use the same rack, cant find the thread now so I cant say if this is a solved issue.
OLDOILER
1,292
Wiltshire, UK
It didn't make any noise with the stock springs.
Note when fitting lower spring the person fitting the lowered springs should ALWAYS undo and re tighten the suspension bushes at the swivel arms [in the loaded position] - failure to do so may cause what you are hearing and also it will shag the rubber bonded bushes over time. .............................................
k04
my friends has fitted the h&r and he has the same sound u r having is there solution for that
lasbazrre
186
Manchester
Had 25mil H&R lowering springs on my S3 now for 3 or 4 weeks , no issues with creaks or squeaks! i get a slight vibration at speed on bad tarmac , but i haven't yet had a 4 wheel alignment, it's time now as the springs have bed in well.
A lot of members on AS.net have used 25 mil H&R springs and spacers with no issues!
leon
pr0ton
Newbie
May 28, 2006
127
It took approx. 2 months & 4000 km's for the noise to disappear.
edit: ...maybe a bit less. Hard to tell exact, because one day I just realised it was gone.
lancey13
i was thinking about getting these springs. has anyone found a way to solve this creaking issue?
