South Wales Cupras Chat
Status
Not open for further replies.
Nov 2, 2004
9,335
South Wales
Text me to let me know tom which one it is. Cash waitin for you, ;)
Also got some stuff for sale soon boys...
Forge Oil Cap
70mm Elbow with Joiner
AC stuff from the engine bay
Ibiza box final drive
Some Forge hoses - elbow off the mani, 25mm elbow, 8mm N75 Hose
Milltek downpipe
Nokia 6500 Slide on Orange
And my left testicle
JamieDav
i am a mechanic and i do know what i am doing as i have had a turbo car before i was just wondering what kind of boost every1 was running so i have an idea what i could run its a jabba remap
Dec 3, 2007
2,475
cardiff
phil ur down the diff???
I might be interested in some stuff. If rhys dont have the forge hopes i might want them. Depends on which ones? Will have to check the fit of that elbow as well.
Nov 2, 2004
9,335
South Wales
The elbow off the inlet manifold is the small one goind to be thebrake servo.
25mm elbow i used to go from the charge pipe to the DV.
And the 70mm elbow is the filter one.
Nov 2, 2004
9,335
South Wales
You probably wont be able to run much more boost than what your jabba map is requesting.
Why do you want to run more? Have you actually seen the size of the turbo? You want more boost/power get a bigger turbo.
I spike at 22.5+psi, not sure exactly as the MAP sensor only reads to 2550mbar which is ~22.5psi then just follows requested to redline which is about 12 ish psi.
Dec 3, 2007
2,475
cardiff
turns out we have a full copy of vagcom now.
And apparently its easy to reprogram a car to accept an ecu. Fingers crossed.
The offer is still there if any one wants to meet up still. There is 4 of us just meetin up casually noting major
Dec 3, 2007
2,475
cardiff
i am doing log's tonight with rhys then we can do ur's on sat. Compare then as well. Not that i will know what i am lookin at. lol
rhysox
Ibiza Cupra 1.8T
Jun 18, 2007
438
Cardiff
i have no idea regarding a refurb kit.. :S
anyway, ye 9 at mcd's is cool with me. i need to get fuel too, or if you want sainsburys just off newport road?
Status
