papaya
BTW - the eBay seller makes a proposal of FULL REFUND MY MONEY with his own PICKING UP of my bad coiovers, so this sounds very fair to me...
its just that it looks like a problem ive seen before on older ibizas with standard suspension, on earlier ibizas the ARB's dont have a collar on them and they can slide to one side causing the drop link to rub and score the chassis. The newer ARB's were brought out with retaining collars. (look closely next to the bushes).
Just what i thought when i saw your pictures!
When was this introduced?
Did you use shortened drop links with yours?hmm bad batch cos mine are 100% perfect not bent at all.....
The issue appears to be that these are designed for use with the standard (long) droplinks as they have their mounts higher to accomodate the lower chassis.
Yours are the type which need the shorter droplinks, as they have the lower mounting positions.I use shorter droplinks with mines.
...neither noise during riding over bumps??? Mine are knocking so noisy in every f*** hole :-( What height You set-up? I tried all - from lowest to highest & still same.
- Bended brackets was due to differences between TA-Technix and V-Maxx and wrong using of shorter droplinks.
- And creaking was because ARB gets different position after lowering. I tried ride my car today without droplinks and creakink was gone! But still knocking...
So I'll go back to my standard SEAT Sport suspension
BTW: Where are You from fr-tdi? I would like to see Your susp. in real...
no noise, no creaking, not bent, theyre slammed as low as they will go, im about 350 miles from you lol near edinburgh i have a normal ARB
