DPJ's Silver Leon Cupra GT - no more.
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
Yes Pat, I was a little nervous about whether they'd fit, but they do, neatly. 11mm spacer fitted to the hub, then disc screwed to the spacer. A spigot goes into the hub end to mount the wheel. Loads of room between wheel and caliper. Calipers are virtually unmarked - off an 05 car.
I'll be honest, I only trial fitted them. I decided I'd get the MOT out of the way and pop them on properly this next weekend. I didn't want another buggeration factor.
Discs are virtually unmarked too - I need to take all their measurements before I fit them so I can source future replacements.
Brought the wheels home tonight with new tyres fitted - they've travelled 3 feet down my ramps!
Safe to say neither cornering nor real braking have been tested then! They do look rather nice though :)
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Cheers.
Before and after
Nov 2, 2004
9,335
South Wales
Yeah i seen those as well, they used to sell them on ebay as i was looking the other day as mine were shot but luckily i got a free set with my tyres as my tyre place had a set kicking about.
You getting water ingress with them dave? Mine looked awful.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Yep, water ingress. The bay is the place, you're right. £7.99 each!
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Fitted the Porsche calipers this afternoon. It surprised me that they weigh less than the oem ATE calipers.
As I mentioned, there are spigot rings that go into the end of the hubs to mount the wheels. The spigot rings were 1.2mm larger than the bore of my hubs :censored:
Solution - I machined the hub ends out. This slowed the job up considerably. Bleed them tomorrow morning.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Corvette, Konigsegg both use 340x32
but I can rule out Corvette C6 as they have a larger bore
If you look at the discs, there are holes for mounting pegs - I've been wondering if they are Mercedes...
Looking good dave.
You've obviously finally lost your marbles and decided to eff it and drop silly money into it.:clap:
I'm only on nodding terms with reality now, John. :D
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
I adjusted the rebound on the rear suspension to 15% off hard and it seems to have got rid of the high speed bounciness. Also fitted 15mm (a side) Eibach Pro spacers (Thanks Badger5) so that the rears line up as nicely as the fronts do.
My, it handles superbly now! :D
