well thanks for all the positive comments everybody it's much appreciated.
Standalone management with als etc...
bill you had any experiance with als? i've been looking at it for a while now, most of the avaliable info seem's to be based on scooby/evo application and everybody say's that the gain to be had from running it is very impressive, but there is also lot's of horror stories out there, most say it severly shortens the life of verious components, (turbo's, manifolds,etc) with some saying that they are cooking gt28/30's in less than four months, although i'm unsure of the application other than it was a scooby.
the plan to start with is to run factory ecu and try to ''manage'' the lag issues with some gas use probable progressive and staged for each gear change. but the car is going to be built up in small stages rather than one big hit as i would like to keep the car usable as much as possible and as we all know everything is dependant on a budget, then when i get to the stage when the factory managment can no longer provide the functions i need then i will change but i belive changing to standalone can be quite a job and from what i have read it's not only the functions that will be gained to consider but what may be lost in the change, however i have no experiance in this area so any info much appreciated.
htc, not to sure about spliting the flange after fabrication, i've looked at many pictures of all types of manifold and it seems about 50/50 on weather people decide to do it, any thought anybody, is it worth it, pro's con's etc
