Whys that then please????
Are you tempted to put it on its stiffest setting and see if it oversteers loads? I would!
I can just about getting under the back of the car to adjust it without needing to put it on ramps.Awesome still haven't returned my e-mail or phone calls about the missing washer![]()
So I went to B&Q to get a bag of similar sized ones and have put them on. I also switched to the medium stuffness setting and although I haven't tested it to much, it seems a bit more balanced like this.
You just need to unbolt the bar and re bolt it on to the other holes. The hole closest to the front of the car is the stiffest setting as I understand it.excuse my ignorance here.... im hardly 'chip foose' when it comes to mechanics....
how do you adjust the stiffness? is it a case of where the droplinks faces? ie, fowards, down etc etc
Yea, the droplinks pivot where they are bolted onto the bottom of the shock. So you can swing them forwards or backwards slightly so they line up with the holes on the ARB. Stiffest setting is the hole towards the front.
how does it handle with it on the stiffest setting?
